Old 03-06-2010, 06:03 PM   #108 (permalink)
aerohead
Elmer's
Originally Posted by 3-Wheeler View Post
Hi Aerohead,
How about taking this a step further to save more cost...
Instead of using Elmer's glue as a barrier, why just use the same glue to hold on the fiberglass itself, as in this example (about 3/4 down the page).
http://ecomodder.com/forum/showthrea...s-10638-3.html
It's lasted over 15 years so far, as still looks good!!
Might just use the same technique on the tail extension. You never know!!
Jim.
Jim,the linear thought progression was too much for my pea-brain! Hiding in plain view,I would have never even thought to just use the glue as resin.
I do like the 'drying' qualities of polyester,where I can continue laminating as rapidly as I can batch and then get into body filler.
But no doubt,short of a crash,a panel or fairing would rarely have to demonstrate maximum compressive strength or adhesion,so the Elmer's obviously is "there" as far a a matrix counterpart for the glass.
That's quite a revelation ! I like it! Thanks for the brain tickle.
I've kept hoping over the decades that I might be able to respect my mind by using it,however,it looks I must consider leaning on others,and their novel ideas to help me along.
P.S. I use the Elmer's Carpenter's Glue,and once it goes off it appears to be fairly immune to moisture.I've experienced Gorilla glue failures and will no longer trust it.
