Howdy blindman_10, does your Ranger have 2 plugs per cylinder? I can't remember if those had mass air flow sensers(which you can clean to improve mpg), or map sensers(check for vacuum leaks). Make sure the engine is running at normal temp. The temp gauge should be in the middle, 195 degrees or so.The operating temp. plays a big role in fuel mileage.
