Airbags are not black magic. Just make sure you never apply voltage to the inflator circuit (not even with an ohmmeter), never work on them without disconnecting the 12V battery, and treat them with the same respect you would treat a few pounds of explosives, because that's what's inside.
As long as you put the same steering wheel back on in the same position, the airbag light should remain off, and you should have no problems with it.
Btw, I like the Terceleporter. What did you replace your passenger side mirror with?
