Originally Posted by Bicycle Bob
My dad never got used to 4-speeds. He called 1st gear "creeper" and only used it occasionally. There might be some advantage to skipping 1st if you are not in a hurry, but I'd definitely use 2nd.
The 2 speed powerglide is touted as one of the most efficient transmissions there is, for power transfer.
That said, without altering the transmission, I'd look at 2nd and 4th with a lockup after 20 MPH.
Shift into 4th while still locked at about 35-40 MPH.
