Old 03-08-2010, 10:01 AM   #2 (permalink)
pgmomni
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
Dave,
I was "stuck" at 32 too until I got that cheapo Air Intake.
Also a new front A/F sensor, removed mud flaps, and adjusted wiper blades as low as they would
go on the windshield.
In my experience exhaust mods tend to hurt mileage instead of helping it.
I think the problem is like the air intake, a variable system works best.
Too little back pressure at low rpms hurts mpg. Too open air intake at low rpms same problem.
Today I am going to add one of those "old fashioned" scavenger tips to my 00 Camry.
All it is a muffler tip that angles gently down off the muffler ending below the muffler and cut at a
angle so its opening is parallel to the air flow. This is supposed to create a slight vacuum effect at hwy speeds reducing back pressure. So no change at low rpm, but small decrease in back pressure at hwy speed. That what we did when I was 18! Now, thats like 30 yrs ago and it probably would be debunked by the "Myth Busters" but its cheap, gets exhaust further away from car and cant hurt.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
