Well done! I see you reached 70 deg c in 40 minutes. Thats fast. I'm currently using 1kw but it takes 2 hours to get to 50 deg c. I'm thinking i should change over the heater to 2 kw as the rate of heat loss seems to be high from my engine. Maybe the extra heat input will overcome the heat loss more?
ollie
