Paul, Adam, I think I found the problem. I am using the schematic to finish my connections and according to Rev "2C" J1 connections 1-5 is the way I connected the wires. Looking at the Pictures in the assembly sheets the connections are the other way around. In the assembly instructions the J1 connections are not documented other than in the pictures. I will try and connect 12v and see what happens.
Mike
