Old 03-08-2010, 10:37 PM   #125 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by 3-Wheeler View Post
Yes, Elmer's glue can be thinned with water. The glue is based on water anyways.
You can heat it AND use a fan to circulate the air around the glued surface. This really speeds the drying process.
As for vacuum bagging, no, this will not work, as air contact is needed to allow the glue to dry. With the glue inside a plastic bag, it will stop drying and stay gummy.
Jim.
Do you know of anything that's anaerobic that might work the same as the white glue?
