Originally Posted by Christ
Do you know of anything that's anaerobic that might work the same as the white glue?
Of course, epoxy has that characteristic, but I don't know of any single part mix glues that don't need air.
Another approach would be a hybrid gluing system.
If you really wanted to save costs, you could use air drying glue for the flatter portions of your creation.
Then use two part mixes for the "corners" that need to be held down to keep it's shape.
The epoxy will stick to the Elmer's and vise-versa. My motorcycle fairing has both glues on it.
Jim.
