Originally Posted by hypermiler01
Two more solutions to belt squeal.
Even if the tensioner pulley spins well, a worn out hinge in the tensioner itself can cause the tensioner to run crooked, which causes the belt to run off-center and at a slight angle.
Goodyear Gatorback belts are worth the extra money. Caravans are famous for belt squeal. I changed the old belt and all the pulleys and tensioner, and still had squeal. Spent the extra coin for a Gatorback belt and it's totally quiet now.
Caravan V6 squeal is usually because of mis-alignment of the accessories, which happens over time due to vibrations.
The actual fix is to adjust the alignment of the accessories which are out of alignment by adding shims.
