I was cleaning some injectors with my homemade vacuum injector cleaner and carb cleaner not too long ago. I realized the gasoline present inside the intake manifold is probably boiling under normal operating temps, this was after I witnessed the carb cleaner exiting the injector went from a spray pattern to a mist once the vacuum exceeded 15 in/hg
