Old 03-09-2010, 08:52 AM   #4 (permalink)
pgmomni
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
My Gen4 doesnt have a distributor...
Originally Posted by sc2dave View Post
what about timing,have you advanced any?
Whenever i had a car with distributor on It always would set the timing at idle to about 10 degrees.
Gen4's have coil packs and static ignition timing is set by the crank shaft position sensor under the timing belt cover.
On Mazda site some members would mod the mount for that
sensor to advance base timing but I have not hear of that on Gen4's on TN.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
