Old 03-09-2010, 04:10 PM   #67 (permalink)
TheSGC
We've had a few warm days here, too. The ForkenSwift's range & efficiency is slowly crawling out of the basement.
ALSO! Since about mid-Feb, the sun actually warms up the inside of the car quite nicely.
I wonder how much of the improvement can be attributed to the Zilla. I don't know much about the inner workings of controllers, but I'd be surprised that there could even be a 19% difference between two different types of mosfet based PWM controllers. (I'm assuming they're both mosfet based.)
The Zilla is IGBT based vs MOSFETS of most other controllers. I think most of my efficiency came from an aligned rear end and the fact that the Zilla can produce the AMPs I need at lower RPMS to maintain speeds on inclines.
I have a lot of battery care to work on this week, but I am hopeful everything will be all set for commuting again.
I also have a bin that I am using to save up for a new set of batteries because I am a feeling the current set won't last more than a few months at the rate I use them at. I have AGMs on my mind.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
