Originally Posted by Weisheimer
Peja,
I sent you a PM response.
You can also use the IRFP260 Mosfets as diodes.
Tie the gate to the source to do that.
I still recommend that you consider the Revolt control board.
You could convert to it later and keep the power section that
you are building now.
Cheers
Mark
Hey Mark can you tell me what diodes i can use for mine controller for now i use IRF540N mosfets for diodes (they have internal like IRFP260) because i don't know what must be used i know that they must be super fast and 200volts or more. I want to build one stable and powerfull controller for 12 volts one for 48volts and who knows maybe one for 144volts
if you know what diodes must i use please tell me
