Old 03-12-2010, 03:13 PM   #3150 (permalink)
jackbauer
jackbauer's Avatar
So the Bauermobile got its first real run today. 3.3 miles of round town driving with some hill climbs in second. 96v of odysssey pc2150 agm batts ,80v compound wound 11" forklift motor , 72v constant shunt field supply. Graph attached. Heatsink peaked at 35c. Motor runs to about 3200rpm under load and 3500rpm no load.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
