Thread: where to start
Old 03-12-2010, 06:02 PM   #22 (permalink)
saddlsor
Front tire deflectors. Find some mud flaps or something similar, and screw them into the wheel well lining. Place them to cover from the inner half of the tires to 3-5 inches inward of the tires, as viewed from the front. You will see that the car companies do it this way, and it is for a good reason, aerodynamically speaking. You can play around with how low to make them, but I would start with them extending 5-6 inches from the ground.
__________________________________________________ _______________
when you did this did you try different angles or just at a flat angle in front of the tires? I'm wondering if it's best to angle them in a little or send the air to the outside of the car. thanks
