Old 03-13-2010, 07:31 AM   #6 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by cfg83 View Post
A Word of Caution:
Unfortunately, that calculator makes the same mistake almost all of them make - they don't consider that the rolling diameter of a tire is about 97% of the measured diameter. That means the speeds calculated are going to be off 3%.
However, since this error also occurs when a comparison between 2 different tires is done, the resulting error is small enough to ignore.
So BE CAREFUL how you use this information.
The Following User Says Thank You to CapriRacer For This Useful Post:
cfg83 (03-13-2010)
