Old 03-14-2010, 05:44 PM   #3 (permalink)
Eddles
Eddles's Avatar
Eddles's Astra - '01 Vauxhall Astra ECO4
90 day: 61.03 mpg (US)
Check fuel pressure - how do I do this?
Engine temperature - the thermostat was replaced a couple months ago as the engine takes 15 minutes to warm up, and sometimes never reach operating temperature. After discussions with other Astra DTi owners, and another ECO4 owner, seems that the engine burns so little fuel, it takes such a long time to warm up the heavy cast iron block. After all, after 4 hours of being parked up in 0 deg C temps, the engine is still hot to touch. Brand new Astra 1.7 CDTi (same engine as mine, but with common rail injection) takes 10 minutes to warm up. So it's normal fare, apparently.
Plugs? Do you mean glow plugs? Wires - it's all digital nowadays, so if a wire is faulty, I don't think the car will work. What wires do you mean exactly? All filters are replaced following the service schedule, but now I no longer have a 140 mile commute, I will be replacing the filters twice as often.
How do I check the compression, and I didn't know diesels had a MAF sensor?
Thanks for your advice though!
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
