Old 03-28-2008, 01:10 AM   #33 (permalink)
trebuchet03
MechE
The Miata - '01 Mazda MX-5 Miata
Originally Posted by Chris D. View Post
your not going to wear the chalk out more or less, your still contacting the road, just not as much..
try putting about 15K miles and hitting it with a depth guage..
Well, I can't do that... Because (as I've already said), I've put 20K miles on... And have measured tread depth... AND have not had uneven wear....
over time tires relax at the belts due to over pressure, depending on the durametor of the rubber, the centers will wear more..
And why would the center relax and not the outers?
I fill my tires with nitrogen now because I got a full tank for free from a friend of mine,
so now my tire pressure stays the same unless I get something stuck in my tire..
4 weeks and my pressures stayed the same and we've some tempuature drops recentally with no adverse effects.
N2 is a whole different can of worms.... N2, will diffuse faster through a substance compared to O2 (just take a peek at a periodic table).... But, considering air is 78% N2 and most industrial gas supplies will bring you to 90% N2.... Whatever - it's 12% more of a gas that's atomically smaller (and thus easier to flow through interstitials and vacancies)... N2 is nice as a source of dry gas - nothing more. No need for air drying and it's very convenient.
Bias ply is a slightly different thing, I'm talking radials.
Bias ply is a very different thing.... Wearing out centers is a bias ply problem, that's something radial tires solved. But, given the ease into the market, the association of high pressure and ballooning persisted. Thus the myth of today...
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
