Old 03-14-2010, 10:54 PM   #2 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
The Civic VX can not have the line on the timing gear line up with the head, instead it lines up with some other marks, not sure what HF you have but it might be the same kind of set up, it's well worth spending $25 on a shop manual so you can make sure what you are doing is correct, don't guess at stuff.
If you are cheap then check a shop manual out from the library.
