Old 03-28-2008, 01:30 AM   #34 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by bhazard View Post
I only worked at the tire shop for a short time, but I did manage to see a LOT of nasty things wrong with tires. Ive seen tires worn in the middle. What else would cause it?
Depends on the tire. IME, the passenger car tires do not wear unevenly in a noticeable fashion at 10psi over the max sidewall. The tires on my light truck otoh have worn unevenly at 10psi over the sidewall. That being said, since the camber isn't adjustable from the factory, and my ball joints are so worn in the front I have negative camber, I run j-yard tires at $20/tire+rim and rotate/flip to get as much out of 'em that I can.
