Old 03-15-2010, 05:20 PM   #38 (permalink)
bgd73
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
Originally Posted by ATaylorRacing View Post
Do not be afraid to go up to the max tire pressure...not much ride difference between 42 and 44 psi. I have also found that those rim damaging chuck holes will often not damage a rim or tire when pumped up to the max...with less air pressure you bend a rim AND hurt a tire!
fwd honda ..and automatic. those motor mounts must have the bushings buried to rock hard already...
try a 32psi tread.
are they 15 inch?
limit stomps on throttle. about all can do.
tricking electronics is all over the place, find some hacks, pretend it is full WOT (working operating temp) all the time.
