Originally Posted by Flatmann100
Good afternoon Paul, my controller is in and I am ready for a 12v low volt test of the system. With power on, run LED on, and the idle LED steady, the main contactor does not close. There is no 12 volt signal at the contactor. Is the high throttle lock out holding it back? Would turning the pot on the control board do the trick? I could fool the contactor and make it close but for the moment I'll double check everything...the car is up on stands so it isn't going anywhere....lol
If the yellow status led is solid, there is so faults, meaning no high pedal lockout. The controller is running fine, it seems that there might be a circuit problem on the board, check the components, see if the optocoupler, and or the transistor are in backwards.
You might also want to download my program RTD Explorer for diagnostics of the controller. You can get it at
RTD Explorer.
You will be able to use it to program your controller and see if there is an faults easily.
-Adam
