Old 03-15-2010, 10:59 PM   #20 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
If I can offer some simple advice:
The engine you pulled out of your Honda is a stressed member, an integral part of the frame/chassis. Make sure you [very] solidly connect the two engines mounts back together when you are finished. A solid connection between the headset (upper engine mount) and swingarm base (rear engine mount) is mandatory, or your frame will snap like a twig and hurt someone.
Very cool project. I've always wanted to attempt something like this with my CB400T2.
