Old 03-16-2010, 05:14 AM   #15 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by wyatt View Post
Once again, the pictures are stolen from team swift. Mine are like this... sorry for the incomplete top gear picture. Rubber belt, 1 - 17mm bolt holding the top gear, 5 - 8mm bolts on the bottom. The reason I wonder is because people on here talk about advancing their timing by anywhere from 3 to 9 degrees, and they talk about it so casually that It seems to me it has to be something super simple like slipping the belt one notch, two notches, etc. The last picture shows the timing belt cover (not mine), but it will show you the 0 to 20, I wonder if that's the advancement...
If you have the 80C/60A cam sprocket, use the 60A timing mark. It's 2° advanced over the 80C mark.
