I still need to look in to my controller options, but if I remember correctly there is a 400amp and a 600amp alltrax that work with my setup and voltage, I think that the 600 amp controller would be over kill, but it would allow me to see what the motor peeks at, then swap to a smaller controller and put the 600amp in my Comuta-car as I still have the relay based controller in there.
My goal is to have this motor, when it hits 2,000rpm for the bike to be going about 50-55mph, I know it's asking alot of this motor, so there are some things that I'll just have to wait and see about.
Originally Posted by TomEV
It looks similar to the motor in your Comutacar - 2000 rpm would be approximately 25 mph which is about where the C-car motor (at least the stock GE motors at 48v) starts to lose torque. But it should do at least 3,500 with no problems.
You're probably right - at 600 pounds the motor won't be working too hard. What kind of controller do you have in mind?
