Originally Posted by mhmitszach
Just tried to different ccrms. One from an early 99 zx2 and one from a 98 escort. Car runs with it, so I'm sure its compatible (4 wire maf)
I'm going to double check this last one with a voltmeter.
The fan does not run now. Ever.
Just because the car will run with either doesn't mean everything will work correctly. I have put different ones on my '02 Escort to see if they would start the car, and even though the car will run all the accessories will not work correctly unless it's the original part number. I have also compared the circuitry on different models opened up side by side and there's definitely a difference.
Unless I am mistaken they changed the CCRM model number on the ZX-2 sometime in the middle of the '98 year model, so one from a late model '98 is probably the same as '99 up, but an early model '98 is different. On the regular Escort one from a '97 will not work on anything '98 and up. I have also seen 3 or 4 different part numbers used on '98 up and I have also compared the circuitry in some of them (opened up side by side) and they were different.
