Originally Posted by LouMan
I got the phase shift idea from my motherboard it has 16phase power to the cpu each mosfet has a 16 clock rest before it has to switch again, I got a pic program to take the pwm in and split it into 4 outputs each igbt will have a 3 clock rest before it has to switch again 4khz from 16khz/4 witch gives the igbt plenty of time before the next cycle,
I will still have 16khz at the motor but each igbt will only be at 4khz,
well give me a email when you get a spare baord & chip
I have not seen the start of this discussion but it looks to me as though each of your IGBT will have to be rated for full motor current.....unless they are overlapping then the first that come on has to handle full current.
I am not seeing what the advantage would be?
