Old 03-22-2010, 11:32 AM   #2 (permalink)
ATaylorRacing
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
The longer the trip the more correct your mpg will be...and more so if you refill at the same pump, same wether conditions, etc. I used to let the pump go on the lowest speed until it clicked off, but there is a large difference in the pumps. On one 100 mile trip the pump would not even stay on since I used so little amount of gas, but the same trip at other pumps always took under 2 gallons to fill normally, and a couple of times they only clicked off after 1 gallon....using those last two pumps would have given me a inaccurate mpg average of 100 mpg..WAY NOT RIGHT. The only way I can think of to eliminate this problem is to install a 4 or 5 gallon fuel cell and fill it up to the same spot every time. The extra 5.5-6.5 gallons of gas that I will not be carrying around when full is worth about .4 mpg better FE.
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
