Sorry Nerys, I guess I jumped the gun. I assumed you were doing this long term.
As to removing the water, I would suggest zeolite maybe or Silica "Gel" beads that come in beef jerky packages and the like. You just have to heat it up to evaporate the water in order to reuse it again. I've heard this is how gasohol home-brewers remove the water from their ethanol before mixing. I would assume this method wouldn't also absorb gasoline.
