Old 03-23-2010, 07:08 PM   #5 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Most cars are equipped with a valve that keeps coolant from flowing through the heater core when the heater is set to "cold".
In the winter, I start with the heater at "cold", then wait for the ScanGauge to show >190°F. Then I set the heater to "hot", and the coolant temperature falls ~20-30°F. I wait for the temperature to recover, then I turn on the blower to heat the cabin.
If it's really cold 10.5 months out of the year (in South Carolina?), you should get a block heater.
