Old 03-23-2010, 10:02 PM   #3 (permalink)
daring4
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
Originally Posted by RandomFact314 View Post
Ok this is a stupid question because I don't know anything about cars really but...
The sensor that is hooked to my intake box that the mechanic said "has a spring and a plunder mechanism that tells the car when its in park" or something like that is broken, I forgot what the abreviation of the sensor was but ANYWAYS if you know what it is...
... Is there any better MPG version of this sensor?
Might be a question that make NOOOOO sence but if im going to replace it I might as well get the better MPG version if it exists...
I dont know anything about sensors or whatever
Do you have a pic of the sensor? The neutral safety switch on auto trannies is what tells the computer the gear you are in. Sounds to me like the air filter sensor to tell you it is plugged up. It has a spring and plunger to measure vacuum on the air filter side. If thats whats it is you can just plug it and not worry anymore...
Darin
