Old 03-23-2010, 10:00 PM   #1 (permalink)
poi_boi_23
Angry Civic VX Failed Smog Twice
So I'm getting frustrated with my civic vx which is my backup car and car that I used for pizza delivery for 8 months while in college. Now that I want to sell it I can't pass smog, even though the last time it was smogged which was 1.5 years ago, it passed with flying colors. Now I'm getting ridiculous amounts of NOX that is driving me insane. I've done many repairs but can't seem to pinpoint what is causing me to fail. Below is a list of everything I've done.
Retarded Timing to 13 Degrees (125,500 Miles)
Recleaned EGR and EACV (125,000 Miles)
New Distributor Cap and Rotor (125,000 Miles)
New Thermostat (125,000 Miles)
Replaced Input Shaft Bearing and Axle Seals (125,000 Miles)
New Radiator (122,000 Miles)
New Clutch (118,000) Miles
Replaced Throwout Bearing (118,000 miles)
4 Wire 02 Sensor (Auto Parts Direct To You)
NGK Spark Plugs (NGK Website)
Fuel Filter (Honda OEM)
NGK Plug Wires (NGK Website)
Exhaust Manifold (Dorman 674-545)
Cat Converter (Dorman 674-545)
OEM Honda Timing Belt Change at 115,900 miles
Water Pump Replaced at 115,900 miles
Replaced Stock Muffler at 115,800 miles
Cleaned EGR Valve at 116,100 miles
Cleaned EGR Ports/Intake Manifold at 116,100 miles
Cleaned EACV at 116,100 miles
While I had my pizza delivery job I had converted the car to Fed with the new ECU, conversion harness, and 5 Wire O2 sensor. After it failed with the Fed conversion I decided to go back to CA ECU and new 4 wire O2 sensor. My results with the CA ECU and O2 turned out worse than the Fed. I have no idea what is wrong. I ran Guaranteed to Pass and Gumout Fuel Injector Cleaner already. I even ran it close to E before my last test and filled it with 1.5 quarts of Denatured Alcohol and still it did not pass. (And yes I've now diluted the alcohol with regular gas.)
The only current problem with the car is that it has an intermittent CEL with code 1 for oxygen sensor or sometimes code 0 for ECU, they are never both on at the same time. I tried switching over to my FED ECU to see if I get a CEL and I get code 41 for primary o2 sensor heater. I don't see why anything would be wrong since I've tried the old and new o2 sensor and still get the same codes. Also, I have an extremely low idle with the car, it will idle all warmed up at about 200 to 300 rpms, it has never died but I can't get it to idle higher without experiencing a fluctuating idle. Oh and the EGR was tested and works fine. Can anyone help out?
ID:	5824   Click image for larger version
