Hi,
I just wanted to show my MPGuino.
I made casing from thin cardboard (about 1mm thick), glued it and covered it with tape. Between PCB and LCD I made supports - little rolls of cardboard and glued supports to PCB (they are not in pictures).
Maybe others get some good ideas from my design
Chip is Atmega 328 - programmed it in freeduino and then put it to my custom board.
Unfortunately my car is broken so I cannot test it in the car
At least it looks neat and compact...
enjoy!
Meelis
LCD disconnected, front view
LCD disconnected, backside view
Between PCB and LCD I made supports - little rolls of cardboard and glued supports to PCB (not in the picture).
Casing is made from thin cardboard. Unfolded
Casing is folded, glued and covered with tape
on the backside I kept some 3cm extra cardboard lip for fastening it on the top of the steering column.
