Originally Posted by Nevyn
The space between the grille and the rad is between 6 and 8 inches; I hadn't thought of that. Thanks though - I'll be sure to check on it. I've heard of other people using pipe insulation foam, or buying a pair of flip-flops and cutting them into strips that fit in between the grille bars.
Never thought about using flip flops, that might be a pretty good idea...
I want to use plexy glass how mine is now so you can see through it and it look 1/2 normal looking
