I have been in the autobody industry for over 30 years and have done a million and one modifications using all kinds of materal. That tee shirt idea is absolutely brilliant!
The plastic filler work seems like a bit much. I would make it smoother with the glass so you don't have to use the filler so much.
At the very least using a polyester primer would be a big help being you don't have to sand out all the spreader marks in the filler. Polyester primer will fill a LOT, you could tape a quarter on your fender and bury it with only a few coats!
Brian
