Old 03-26-2010, 04:27 PM   #1 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Underbody panel testing
I found this in Piechna's book. Sardou ([1]) tested underbody panel configurations on the same car in different wind tunnels, both and without a moving floor.
The chart below shows how adding different underbody panels influences aerodynamic drag and lift, but also lift for the front and rear axles.
Worth noting are two things:
  1. Adding panel #1 down the center increases drag,
  2. Adding the center panels (#'s 3, 2, and 1) decreases lift in the rear.
[1] Sardou M., The Sensitivity of Wind-Tunnel Data to a High-Speed Moving Ground for Different Types of Road Vehicles, SAE 880246, 1988.
ID:	5857   Click image for larger version
The Following 12 Users Say Thank You to Piwoslaw For This Useful Post:
aerohead (03-26-2010), AeroModder (03-26-2010), Bicycle Bob (03-27-2010), Cd (03-29-2010), jime57 (03-26-2010), landsailor (06-19-2012), mcrews (03-26-2010), moonmonkey (03-27-2010), Nevyn (03-30-2010), rbrowning (03-27-2010), TEiN (06-17-2012), whatmaycome14 (07-27-2014)
