Old 03-26-2010, 07:52 PM   #16 (permalink)
Bajascoob
BigWhiteWhale - '01 Ford F250 Lariat Crew Cab Superduty
Originally Posted by nowhhs View Post
I've bypassed the neutral safety switch in a 1976 Chevy van for over 20 years and not had a starter failure. My ignition switch went bad, so rather than replace it, I just wired in a relay and a push button switch (I was poor at the time) and its worked fine ever since (my dad still owns the van). And I've often started it in gear. It is a little weird to start moving as soon as the engine starts though. At cranking speed there is very little resistance from the torque converter, so it doesn't really add much to the starter's load. The reason manufacturers don't let you start in gear is strictly liability, remember Audi's "unintended acceleration"? That wasn't the same issue, probably a pedal placement problem, but the point is the same. Imagine what the average driver with a cup of coffee and a cell phone would do if the car started moving as soon as the key was turned and you see the problem. If I was going to wire something like this up, I would probably use a three position toggle switch mounted within easy reach with the center position normal, one direction kills the ignition / injectors, and the other direction to the starter. It would also allow easier EOC if you're so inclined, which saves a lot more gas, according to the people who do such things.
The transmission safety switch on my off road race truck is bypassed, I occasionally start it in drive if it stalls while racing etc. It's an auto trans, the starter doesn't make the truck move that much until I punch the gas. There is more load on the starter but I don't think much more. The auto "free wheels" until enough rpms are built up.
