The t/c has a stall speed in most passenger cars over 1200 rpms, the starter rotates the engine nowhere near that speed. The t/c is bolted to the ring gear and is always turning with the engine. Its just a safety feature that you have to start it in park, apply the brakes then pull it into gear, with the exception of being able to start it in nuetral. I guess thats why its called a nuetral safety switch and not a turn the key and see what happens switch!
I guess my point is, you cant do any damage internally starting it in a gear.
