Gapless Rings
Will, Thanks for the reference to Total Seal. I'm in the process of putting together my G10 XFi engine and was totally dissapointed when I got my Sealed Power premium rings in today. As you indicate, they are not the gapless design so I called Total Seal. Their rings are not the same as the OEM design but should address the same concept. My Sealed Power rings are going back and I'm putting together my order for true gapless. As for using the old rings, that's a poor path to go down. The whole discussion on ring tension is mostly not a player but the problem is, as you can guess, wear.
