Thread: o2 sensor mod
Old 03-31-2010, 02:18 PM   #7 (permalink)
tangomar
sukisuki - '00 Suzuki Grand Vitara 4wd
90 day: 21.88 mpg (US)
Carlos is right.
You probably have multiple O2 sensor and you have to fool them in the same way. This means that you might need 4 EFIEs. At that point you might need to adjust MAP/MAF, TPS, IAT, ... as well.
Isn't cheaper to remap your ECU at that point? You can have it tuned perfectly as you wish.
Another way to do it is to use a Volo Performance chip. They are quite cheap right now: FS1 Fuel Saver
They soft patch the ECU continuously. Some people reported good savings on another forum.
I would still monitor the exhaust temperature to make sure you aren't going to burn anything.
