Old 04-01-2010, 11:37 PM   #13 (permalink)
bgd73
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
11.0 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder. Unleaded fuel 87 and petrol.
Read more: 2011 Ford Fiesta SE Sedan Options - 2011 Ford Fiesta SE Packages - Motor Trend Magazine
it is a goner already. if engines are cheap, valve craziness set to solid, and maybe a thick head gasket getting it down to 10 to 1...maybe a buggy to keep when it gets old. that drivetrain is a tharsher..trying to make a hot rod apparently.
the 195mm tread at 15 inch with 1.6 liters makes me happy.
that is about it.
