Hello -
This is another one of these gizmos :
http://ecomodder.com/forum/showthrea...ons-12720.html
Hot Inazma Pocket Super (Capacitor)
Do NOT mistake this as the older "non-Super" model please! Hot Inazma Pocket Super is a new voltage stabilizer based on Hot Inazma technology. This new 2009 "Super" model uses higher-capacity capacitor than the original one. Connect it to your cigarette socket to get peak operation efficiency. A/C, stereo, lightings & many other electrical components in your vehicle are constantly creating a load on your car's electrical systems. These cause fluctuations in voltage which prevents the vehicle from performing at optimum efficiency. Hot Inazma Pocket is designed to stabilize battery voltage for enhanced electrical system efficiency. It also saves on gas, reduces emissions, brightens lights, reduces audio noise interference, purifies the cabin air by emitting negative ions (rated at 2,500~3,000 ions per cm3). New 2009 model uses dual 470 µF capacitors.
Yours for $135. But, at least they don't claim an 18% increase in MPG.
CarloSW2
