Old 04-04-2010, 02:13 PM   #9 (permalink)
pgmomni
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
Now that its warm out I can get to change the gear oil in tranny..
Originally Posted by wriley4409 View Post
I would replace the transmission fluid with a pure synthetic lube of the same type as called for in the owner's manual. (I believe that this would be a GL5 spec 75W90 gear lube) This change would improve your gas mileage by a few percent.
Domman56, my car doesnt have a distributor so only way to advance base timing is to modify the crankshaft position sensor located under the timing belt cover. Something one doesn't remove until the timing belt needs to be changed.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
