Old 04-04-2010, 09:20 PM   #1 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
How to test your gas for ethanol...
1) Buy a 10 ml graduated cylinder
2) Mark an extra 11 ml line above the 10 ml level
3) Add 10 ml of the gas you want to test
4) Add 1 ml of water up to the new 11 ml line
5) Put your thumb over the top and shake the sh*t out of it
6) Set it somewhere and let it settle
7) If you now see 1.5 ml of separated liquid at the bottom...you have approx 5% gasahol.
note...some of the separated liquid will stick to the sides of the cylinder...and I'm not totally sure the 1 ml of water is enough to draw out all of the ethanol....or whether it also draws out other elements of the gas.
Graduated cylinder - Wikipedia, the free encyclopedia
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
The Following User Says Thank You to suspectnumber961 For This Useful Post:
5speed5 (04-05-2010)
