Old 04-04-2010, 08:26 PM   #197 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by IsaacCarlson View Post
I have two solenoids....can I just use the 12v solenoid and ignore the pwm solenoid? I think the 12v solenoid takes over after the pwm solenoid engages smoothly. If this is the case I would like to just use the 12v solenoid.
If not, how long should the pwm solenoid be connected to 12v to test it?
I can't answer those directly, but to test the solenoid, you just test it for a few minutes to make sure it doesn't overheat/fail. As long as it's not getting hot after a few minutes, or hasn't already failed, it should be OK.
