I'm using a Pure One PL30001 filter on a 1.5L Toyota engine. Also trying Mobil 1 0W30 synth oil. Expect to run this a full year...with maybe a filter change midyear. Will probably add 3 qts oil over the year?
I consider this a cheap to use and install bypass filter.
The filter on the left is the regular NAPA filter for the car...the one in the middle is the Pure One version for the car...the one on the right is the PL30001 "Mustang" filter.
