Old 04-05-2010, 09:16 AM   #22 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by suspectnumber961 View Post
I'm using a Pure One PL30001 filter on a 1.5L Toyota engine. Also trying Mobil 1 0W30 synth oil. Expect to run this a full year...with maybe a filter change midyear. Will probably add 3 qts oil over the year?
I consider this a cheap to use and install bypass filter.
The filter on the left is the regular NAPA filter for the car...the one in the middle is the Pure One version for the car...the one on the right is the PL30001 "Mustang" filter.
While this is probably a fine oil change strategy, it is not a bypass system.
Bear in mind that you will probably never plug that filter, even over the entire life of your engine without filter changes.
How many miles are you driving per year? 3 quarts seems like a lot to me, any leaks?
Also be sure that your filter has the proper valving (drain back, bypass, etc)
If you want a true picture of your engine/ oil send off a sample to a lab.
2012 Tesla Model S P85
2013 Nissan LEAF SV totaled by now deceased intoxacated driver.
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
