Old 03-30-2008, 10:35 AM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Unreliable results measuring MPG / overinflation valve stem failure
Yesterday, I aired my tires up to what I thought was 50 PSI. It turns out it was closer to 65-70 PSI - but this measurement was taken after the blowout *on a ( very ) hot tire. ( Maximum inflation listed on the tire is 44 PSI )
I was in a hurry and did not check the PSI using more than one guage. I have found ( and especially yesterday ) that tire guages are horribly inaccurate sometimes.
I guess I have found my limit, because I had the blowout. Thankfully, what occured was that my valve stem developed a large leak around its' base - so there was no dramatic explosion like I always feared.
( I'm not saying that an explosion could never happen, but thankfully this time around it didn't )
The tire is fine, but needs the valve stem replaced.
* On the tires that weren't blown of coarse .
