Originally Posted by dcb
If you could post a schematic that would help.
IS that for me??
There are three VSS outputs in my van: one from the transmission that goes into the VSS Buffer and the two out from the VSS Buffer, one to the speedometer and one to the ECM.
I am running on the speedometer's and it seems to have some steady output that seems to make the MPGunio count miles ever standing still.
Can I use the raw output from the transmission? OR should I use the one to the ECM?
Rich
